Brief Description: Nose wheel fairing preparation...
Today I returned to working on fiberglass fairings in preparation for painting. I started by sanding the nose wheel fairing after the micro application. I also installed it and checked the openings for the tow bar attachment. Both holes needed some enlargement. Then I sanded the main gear leg fairings, the VS to HS fairiing and the nose gear leg intersection fairing. Lastly I sanded the upper cowl inner face and applied micro to it.
Nose wheel fairing sanded after micro application
Upper engine cowl inner face sanded and micro applied
Main gear leg fairings, nose gear leg intersection fairing and HS to VS fairing sanded after micro
